New engine help
92 Ty 1173
Ok, got the new engine in and all wired and fluids are correct. I am looking for any suggestions on what the problem may be, or perhaps a check list of things to check. The engine will turn over but not start. I thought I was 180* off so I redid the timing but still no luck. Fuel pressure is at 55 psi and I have spark. Not even a sputter or a back fire like the timing is off. Any help/suggestions would be greatly appreciated. Thanks, Jason.
92 Ty 1173
Re: New engine help
Keep em coming. I quit for the nite gotta be at work early tomarrow. I'm going to continue trying when I get home.
blackty
Re: New engine help
Is this a newly built engine or a new-to-you engine drop in? 55psi seems high if it is a stock build. Triple verified firing order? Compression / valve adjustment? Correct plugs / gap for your application? Just a few thoughts...Jim
92 Ty 1173
Re: New engine help
New build, used 412 cam,new crank, all adjustments were made on the engine stand. Cam timing at 0*. Had spark last nite at the coil, I called it a nite before I checked the for spark at the plugs. Not totally stock, I have 8.5:1 pistons, 2.02/1.60 valves, 412 cam, walbro 255 pump, and an ultimate chip. 55 psi is where I had it before the rebuild. I'm gonna find TDC again later and recheck the plug wires also.
92 Ty 1173
Re: New engine help
But it's been my experience, with carberated anyway, that 180* out it will pop and carry on, right? I'm gonna check it anyway. I can't wait to leave work, I've got such an itch to hear it run. Been almost 4 years since I drove it.
denny
Re: New engine help
I started my engine (new build) for the first time and it its start first crank.
If you are getting fuel and spark then it should at least attempt to start.
You must know this already but this is what I would do -
1. Rotate the crank with a socket set to to 0 deg /TDC
2. Remove distributor cap – see that rotor is pointing to the #1 cylinder direction.
Loosen the distributor hold down bolt, have some one crank the engine while you slowly turn the dis side to side until it hopefuly starts.
92 Ty 1173
Re: New engine help
Gee thanks, rub it in. LOL Yeah I did that last nite but I'm gonna do it again today with a clear head. I put the engine in at TDC but wasn't thinking when I rotated it to bolt up the torque converter.
Not that old. I had the truck running before I swapped engines. It's been about 3 weeks.
92 Ty 1173
Re: New engine help
Ok, I figured out that I adjusted the valves too tight. Gonna readjust them and check compression. Anyone know what psi a new engine should test as??
bezerk
Re: New engine help
if it's a new engine it might be less, if the rings have to seat themselve.
