93_Typhoon#1914
Here's the deal, drove my truck a couple weeks ago and got a check engine light. Took it to Roy's place (BlackKnight), ran the truck with his scan tool and got around 8-10 degrees of knock retard at about 10 psi. Since then i've been trying to figure it out. Took it out today with a scan tool i bought today to see what is going on. Here is what i found.
Check Engine Light: Code 44 Lean
Knock Sensor: 230 (High)
Knock Retard: about 5 degrees depending on boost. Sometimes it was fairly low like 1-2
O2 Sensor Volts: Erratic from 200-800 depending on driving.
O2 Cross count: 230
Vacuum Sensor: 4.11 Volts
Lean Flag under boost
I've searched and can't really find what i'm looking for. I'm pretty new to these trucks and i'm kinda lost here and don't know where to start. Any help would be appreciated on what to check. Ask me if you need to know anything else and i'll let you know.
O2 Cross count: 230
