+4 on the RPM kit. It's what I'm running, and it comes with every fitting you need to add a B&M cooler in line with the stock radiator cooler.
Yes sir, that is correct. They include the 1/2" NPT to AN fittings for a B&M supercooler, the fittings for the transmission to convert to AN, and the fittings to convert the radiator to AN. All of the stock lines and fittings can go.
http://www.sytyperformance.com/inde...facturer_id=0&option=com_virtuemart&Itemid=26
Thanks man. I'm most likely going to buy these since I already bought the b&m super cooler from RPM.
I have a complete set of hoses as in the rpm link. New, it didn't work for my 80-e conversion. P.M. me if your might be interested in them. All I used was the transmission cooler.
