MD need code59
greg orndorfff
gregs sy
running ATR cam with a 67mm turbo..when I put in the 50lb. inj. it run pretty good but surges and at idle it will stall out sometimes...Was told by someone to junk the ATR chip and go CODE 59. need help. Sy went 11.78 9yrs. ago on 21lbs of boost and street tires...Need a code 59????thanks. GREG O. Md.
RealFastV6
@jb_and_his_coffee
Code 59 isn't a "thing" you buy. It's an alternate code that you run on the ECU that provides additional features and adjustability. You run it on an Ostrich or you get a chip burner and you burn chips.
A Turbotweak chip might be more your speed. Just my humble opinion.
