SY2932 said:Fuel pressure is number one followed by transmission temperature IMO. Our transmissions can give us SO much grief, it makes sense to know if it is "cooking itself to death" just inches away.
VermontTy said:Too many gauges....so little room!
VermontTy said:SY2932 said:Fuel pressure is number one followed by transmission temperature IMO. Our transmissions can give us SO much grief, it makes sense to know if it is "cooking itself to death" just inches away.
turbodog said:VermontTy said:Too many gauges....so little room!
This is why I have a '4-input' setup for pressure, and a '4-input' setup for temp. I can crank thru them and check general health, then leave them set on the critical 2 (yup, trans temp and fuel pressure, I agree) for full-time monitoring.
ty1724 said:who makes that gauge its sick!!
VermontTy said:I'd also like to know where you got that gauge, turbodog.
susp and trans pressure??? where do you have these senders hooked up?turbodog said:
turbodog said:Wondered if anyone would notice. I do have a sender on the rear air susp, as I have an override I can use to bring the rear up to stock height (or higher) for pre-meditated launches. The guage allows me to to so repeatably (without getting out and checking with a tire guage in the fenderwell, where I have a shraeder valve plumbed in).
As for 'Trans', well, the indicator bars come in mutilples of 2's so I had to put something on the label. No sender hooked up on position #4. In hindsight I should have put 'flux capacitor' on the label. I may get around to printing a different label. It's just ink-jet printer on transparent mailing labels.
ghettosled said:turbodog, that gauge looks really nice. Would work really well for anything with a range of 0-100psi.
