Need AFPR recommendation.
TY162
I have my Walbro pump on the way (good thing too, I have 0 psi today) but I'm wondering what AFPR set up people are using or recommend?
Thanks,
Scott
Don W.
Re: Need AFPR recommendation.
Plumbing doesn't change. It uses the stock fuel rail and the stock return line. Access can be an issue but that a different question.:rotf: Held in by 2 Allen screws. Just be careful to not cross-thread anything. You might want to change the o-rings (if it doesn't come with new). Common item at the parts store. Never install o-rings dry. Wet them with a small amount of motor oil.
Have a rag underneath to catch spilt fuel. DO NOT attempt when motor is warm-hot.
You say you now have -0- fuel pressure This implies you have a gauge setup. You will need one to set your system pressure once you install this thing.
