My Typhoon hates me ...
jjorgensen52
NHSTE - I'm the only one!
So, as some of you may remember, my Ty has been down since November with a low oil pressure difficulty. Saturday I pulled the pan off the truck and found an M55 in there, but the pump is perfectly intact (thank goodness). Replaced with a new M55HV instead
Okay, assuming all is well, go to put the pan back on, but just on a hunch decide to wipe the last little bit of oil residue out just to make sure that nothing has made it's way into the pan. Find these
:eek:
Not sure what to do now, so made a few phone calls and went by the local machine shop (built the motor)... consensus is they look like retaining clips from a hydraulic lifter. So, off come the valve covers. Driver's side, fine. Passenger's side, all looks well... on a hunch, again, pull off the one rocker that feels a little bit looser than it should. :rant: Bingo... no retaining clip, lift out the pushrod and the top of the lifter comes with it. So then, 45 minutes later, I have this
and a pair of these
Funny, this project started out as simply replacing an oil pump, and now I'm 2 extra hours into it and have the top end apart too.
In the morning, I'm going to search for a pair of Comp hydraulic lifters to match the ones in the truck, so that hopefully I can put it back together again. :banghead: Nothing is ever easy, is it?
alwayscode390
pppssssshhhhhtttttttttttt
Re: My Typhoon hates me ...
What lifters are those ... I dont want to make the mistake of buying them, lol ... good job so far. I hope no other damage was caused before those things made it to the pan ---
jjorgensen52
They're a comp anti-pump up lifter, not sure exactly which ones (believe they're pro magnum hydraulic, but not 100%) ... so far as we can tell, nothing has been injured except the two lifters themselves
I'm running a Comp 422 by way of cam... little bit much for this motor.
I'm not sure that I'm going to replace them all yet, I'm going to talk to the shop that built the motor when they open today, and also going to go check the other ones over really carefully to make sure that none of them are waiting to go, either.
jjorgensen52
:rant: :rant: :rant:
Got the truck completely reassembled last night, the only incident being priming the oil pump without the filter in place (boy was that messy :doh: )
Anyway, turn the key, coughs about 3 times and .... nothing. No start. Got a nice healthy spark to it, but it's getting no fuel... as far as I can tell, I have no injector pulse (about 38 - 40 psi fuel pressure)... didn't but a noid light on it, but I did feel the injectors while cranking and I can't feel them clicking
Tooky
Serious about performance
Are those the Comp 875 "race only" lifters I talked about in this thread? http://www.syty.net/forums/showthread.php?t=53610&highlight=lifters
There is a link in that thread to an F-Body forum where that lifter is known for a failure just like you experienced. I'm running one SpeedPro stock replacement HT2148 (and 11 stock lifters) up to 5500 RPM so far with no problems on a .530" lift cam.
jjorgensen52
The same lifters. They are actually run, by comp's recommendation, at 0.000" preload because they are a non pump up style lifter. I did use the same again when I replaced them, so we will see if anything else goes awry with them. I also have had my motor revved up as high as 6200rpm, figured it was floating valves at that speed... all were intake lifters that were broken
