Hi all,
It's me again
... Well, guess what? I replaced my map sensor with a new one(my dad got home with a new one
) hoping to solve my problem once and for all. I changed it and the truck wouldn't start :drinking: . I tried a couple of times and wwaala!! It started but, it was hesitating and fighting to stay alive while the RPMs where dropping till it eventually died :x
I started it again and this time the truck was idling at 1,200-1,500 RPMs
I let the truck rest at idle and when I got back it was idling somewhere in the 900-800 range. I took it for a spin and it felt like normal while I was getting it out of my garage. Well, I thought I had solved my problem. The truck was running fine till I got it into boost. It wouldn't build more than 5 PSI and it felt like it was triyng really hard to build boost.
So, I put her back in the garage because it was raining 0X and I couldn't work under the rain. I took her out today and it wouldn't start. It started and I would move 5 feet and it would die I had to start it like 5 times just to get to the front of my house :x
well, I decided to change my plugs so I lifted the truck, got the front wheels out. I noticed that the plugs where all tight, and the wires were ok. I looked carefully at the plugs and noticed that the white area(creamic) at the begining of the plug was black in all of them.
I was triyng to get them out, but it started raining and I couldn't. Could that be my problem???
Thanx.
It's me again
Thanx.
