Re: LSX Swap Mounts and Oil Pan
I am doing the swap right now. I started out with the modded H3 pan and the Dirty Dingo mounts. Note that the DD mounts sit the engine up pretty high and I had to modify the trans tunnel. The RPM stuff on the other hand sits the engine really low and you need almost no tunnel mod. The difference between the two mounts doesn't look like much but it is a drastic difference in height and trans tunnel modification. The RPM mounts don't work with the H3 oil pan, so you would have to build a mount and try to sit it a little lower than the DD mounts, I think that would be the optimal choice, because the H3 pan has the oil filter on there.
