laptop engine tuning . where to start
canuck
i own a buick and theres a program u run to play with engine parameters.
is there a tell all sticky on the avenues that can be travelled, concerning how to approach and what can be done. or a link.
thx dave
willyson
trollin'
Re: laptop engine tuning . where to start
here is a gist of what youre looking for:
tunerpro rt and files can be downloaded at nwstp.com
obd1 cable aka datamaster cable - check vendors
flash n burn g1 chip or ostrich moates.net
datamaster is used to monitor data, not actually tune. this is where tunerpro rt comes in
Flyin Ryan
hated cuz he drives fords
Check under the "Chipping, Emissions, Tuning" section on this site and you'll find a few stickys but also do a search for code59 or visit www.code59.org
JS Manufacturing said:
My suggestion is
www.nwstp.com has the definition files for tunerpro you need and we try to keep them updated as bugs/errors are found.
I suggest new people play with the closed throttle VE table. Put the chip in open loop and play with adjusting those #'s to get the idle AFR where you want it. Save your old chip so you can always go back. You can't do much damage aside from fowl plugs in the closed throttle table so don't fear anything. Get it to idle well in park, figure out how VE adjustments affect AFR's, etc. Then put it in D, sitting there with brake and get that part of table fixed. Go back to Park (it will change) find the happy medium. Remeber you can't do much damage in closed throttle so try things. Get a good feel for what is going on.
Once you feel good there, drive at say 35mph steady see what cells are being accessed and what AFR you have. Make adjustment. Then do 45, 25, 55, etc. Get the main VE table so that AFR is where you want cruising steady state. Get that worked out and you will be amazed at how much the other stuff will fall into place. (stumbles, bogs, spool, etc.)
Everybody wants to tune boost first which is WRONG. The way the stock chip calculates fuel under boost forces you to have the drivability stuff first. Concentrate on drivability first.
When I do a custom tune for someone I spend 95% of my time doing drivability. Fuel under boost takes about 3 runs. Drivability can take a couple hours or more.
