sytygmc said:
i can hear the knocking at open throttle and makes the ty bog forcing me to let up. friend used scan tool a year ago and ty was running at stock boost, around 14-15. i'm using stock chip. no major mods, just open filter, borla cat back. i changed cap and rotors, wires and used stock plugs. ty is running better after tune up but there is still some knock at wot.
Forgett the throttle for a while and get a DM hooked up ASAP. As I've mentioned it still can be caused by a bunch of things. Do you get error codes as well (check engine comes up)?
You fueling system could be out of pair, bad fuel pump, injectors, regulator, dirty filter (when was the last time you changed it?), etc... DM will give you an indication wheter it's lean at WOT or not. If it's lean you will have to find the weak spot in your fuel system.
Overboost could be an other reason for knocking. You have a non stock exhaust...
Find someone with DM and post the results here...
BTW, could you post what do use as stock plugs?
Later,
