Re: Knock Retard
Now that it has stopped raining out, I did some testing this weekend with EGR block off and New Injectors, It still has knock retard issues, the new injectors didn't fix my issue :rant: I get knock retard pretty much as soon as I hit WOT. The truck is still on the rich side as the 02 were high 900, I will have to back down the fuel some, but its definately not going lean. I am still not convinced my truck pulls timing past 0 degree, but it said I was pulling 18 degree plus my timing is already retarded 8-10 degree :shocked!: At the very least, its pulling 20 degrees of timing.
I also aparently have an overboost issue with cold the weather. I have my boost set for 16psi in the ultiamte chip type program I am running and I easily hit 18psi before I backed off the gas. I disconnected the boost solenoid, so that I have base boost and I hit 16psi easily and I think it would have crept up to 17 or 18 psi. In the warm weather, I hit 13-14psi easily with it creeping to 16psi. So I will have to deal with that now...
I have a modified intake and a set Vortec Heads (Which I sliced my hand read good on yesterday and bled for 2 hours.) I think it might be time to pull the top end of the motor apart.
