Interior panels- Need help!!!!
souljasmooth
I am considering purchasing a Typhoon, but have a question about it. I was wondering if all the panels- front dash, glove box, center console, and all rear panels are the same as a Jimmy? The reason why is I am looking at a Ty with 75K miles, but the interior is beat up, especially the panels. It looks like the owner hauled stuff in it. I was thinking I can change out all the panels listed above and re-carpet it for cheap. I am hoping that there isnt special Typhoon panels that I have to get. The outside body looks good, and the engine is okay, seats are okay. What do you guys think? Is there anything else I should consider when looking at this Ty? Thanks in advance!!!!
Re: Interior panels- Need help!!!!
There are a lot of things to consider. Chances are that if it needs a lot of work youll be sick of it in no time. Even a truck that doesnt need a lot of work can break frequently and htat on top of have to fix a bunch of interior crap can surely drive a madman crazy. Im pretty sure the door panels are SYTY, dash is S10, glove box door is SYTY but only because of hte emblem. As far the panels go they should all be S10 as well. Carpet, you should be able to get fairly cheap but it is a PITA to change out, in any car really. Where is htis truck located? You should have someone on here check it out with you.
poorboy93
Veteran S10 Owner
TYTILLIDIE is right, and the S10 door panels will work, but the SyTy has specific leather inserts and certain style steering wheel. Also remember (judging by your Q? thread) when getting replacement pieces for the dash that you get one w/ correct options, RE: fog lights, power mirrors etc. And a power screw driver saves so much time/effort for changing panels to get to said carpet. good luck.
Here's the buyers list courtesy of sytyauthority.net
First off, Remember that we are talking about a vehicle that is 15 years old now.
(Poorboy edit:) dont forget the jackstands! :lol:
Never buy a used vehicle at night no matter what artificial light is present.
Motor:
q Does it smoke a little at startup? Could be valve guides
q Listen closely (at start up and when warmed up) for exhaust or vacuum leaks.
q Check for oil leaks around heads and turbo supply lines running to and from motor.
q Check ALL fluid levels and textures (smell) (oil, trans, p/s, p/b, coolant, intercooler) hot & cold.
q Open oil filler while engine is running to check for blow by. Could be valve seats or rings.
q Check turbo & intercooler plus hoses and connections for leaks.
q Check condition of belts, hoses, wires, battery.
q Keep an eye out for missing fasteners. Indicating sloppy repair work.
Transmission:
q Check around pan and housing for seal leaks.
q Check the feel of tail seal coming out of transfer case and first U-joint front and rear.
q Check for Aux. Tranny Cooler?
q Observe the fluid (smell feel level) cold / hot.
DriveLine:
q Check rear driveshaft & U-joints; front propshafts and CV joints for tightness.
q Check transfer case and all differentials for fluid leaks and signs of opening.
q Turn vehicle in tight radius both directions listening for CV Joint popping.
q CV Joints need to be clean and free of cracked boots.
Suspension:
q Check shocks for leaks (front and rear).
q Leveling system in tact & working.
qBall joints & Tie rod ends tight and crack free.
qSteering tight and free of "play".
q Rear leaf springs tight and squeak free.
Brakes:
q Pads thickness and color, OEM?
q Disks color and wear.
q Lines / fluid condition.
q ABS can be hard to test but if you get the chance, you better.
q Emergency brake functional. May need this later for Killer launches
Wheels/Tires:
q Check wheels offset and correct rotation if possible. Mine were switched F to R. Looks pretty silly too
q Check tires wear and wheel edge condition.
q Locking Center Caps (stock) Locking Lugs? Key?
Body:
q Check hood / Grill area for damage/repaint?
q Check cladding for cracking paint and rubbing into body paint.
q Bottoms of door edges for rust.
q All inner fender wells and behind all fender wells for rust (back window hinges).
q Do the doors / body panels line up and close tight/straight? Cladding has been known to not fit perfect.
Interior:
q Check for wear in all leather (edges of seats, steering wheel, gearshift knob).
q Manuals, Literature, extra keys, keyless entry transmitter included.
q Check A/C for coldest and Heater for hottest. Rear defrost & wiper too.
q Cruise control may act strange but check for usability.
q All Stereo functions in working order. (CD player works smoothly, Speakers not blown).
q Power accessories (windows, locks, seat, mirrors, keyless entry, hatch releases, lights, signals).
q All trim panels in place and securely fastened, no screws clips missing.
q Check F/R Ashtrays in "Non-Smoking" vehicle. Mine was sold as a "Non-Smoker" and had ashes in the back seat trays
souljasmooth
I appreciate the help. I am in Oregon if someone wants to come check out this Ty. The body paint and engine look descent. It is mainly the plastic panels in the back sides and tailgate, and the front dash. The truck looks like some used it more for hauling than for racing. I did notice the hood being a little wobbley when it is up. If most of the interior plastic panels come from a Jimmy/S10, I may purchase this truck. Changing out panels and carpet is not a big deal to me. I was more concerned with the cost and availability of the parts. I would rather purchase a truck that someone abused the interior, than raced and abused the engine. Also I am really considering this truck because it is my favorite color Garnet Red. thanks again.
poorboy93
Veteran S10 Owner
GARNET?????!!!!!!! buy it dude. simply put! That is one of the more rare colors, and just wait untill some of the other Garnet owners here chime in!! :D
On another note, yes I agree with the hauling/racing observation on the motor. But w/ it bieng used as such, make sure to check out the rear shocks and rear leveler control. If it's bad, it's common and just replace w/ shocks of choice. I recommend Bilsteins. And the loose hood is an ez fix too.
souljasmooth
There is a good chance I am going to pick it up. Also, I am looking at purchasing a 91 GMC Jimmy with near perfect, all grey interior for next to nothing. Will all or most of the panels be identical to the Typhoons? I know seats, doors, and steering wheel are different. thanks!!
AUSyTyIN
Unbusted $#it box
The door panels are different, the glovebox has a specific emblem, the center console is different, as well as the gauge cluster and bezel.
poorboy93
Veteran S10 Owner
Yup, all direct fit, so your good to go.
souljasmooth
Are Typhoon interior panels suppose to be black or gray? I know the dash is gray, but what about the rest of the panels in the truck?
