Info on a stealth 70
badasiwnab
I've heard about these turbo's but I can't find any info on them
such as inlet, outlet size, price, horsepower rating and if anybody
is using them. And just about any other info I can get.
Raist103
Engine Killer, iPhone Killer, Lawnmower Killer
lots of people use it, 3" inlet and you can get diff size outlets....good for like 600-675hp most people bought them because they thought it was the biggest turbo to use with ac but you can use bigger...i hear it is a good turbo with low stall needs but never used one...
ghettosled
SYTY SUPERSTORE
its basically the largest turbo you can use with a 3" inlet. Depending on your header/radiator setup a 4" inlet could be hard to adapt an air filter to.
Basically PTE termed the name "stealth 70" eventhough it uses a 66mm compressor wheel. They also use a certain garrett compressor housing which has the additional meat to machine such a large wheel in a small inlet. Specs should be 66mm comp wheel, P trim turbine, 3" inlet, 2.5" discharge, any turbine housing a/r. I would say 600-675 would be a good power estime as mentioned above.
At this point the 3" inlet/air filter setup will be your biggest restriction.
tbauer03
TRBOBOX
I got one on my Typhoon but I am still finishing up the motor build but i will let you know about it when it first sees boost.
tbauer03
TRBOBOX
yeah i'll let you know, I am going to be running it with a 28k 9/11 converter and a built motor with vortec heads and a 422 cam so i am hoping that stall will work out well. We actually got the typhoon running for the first time in 10 months yesterday so that is pretty sweet but i can only work on it on weekends due to college, hopefully next weekend i can give some feedback but i doubt it, i want to break the motor in gently and then start playing with boost.
