I need some newb help...
Mad Dog Tannen
I just got my typhoon running again after installing a new A2A intercooler, underdrive pulley and battery relocation. It just doesn't seem to be running right now.
It hesitates when I hit the gas hard (sounds like it misfires or something). It almost dies when I go around a sharp corner. And the BOV makes a choppy sound instead of the crisp sound it used to make.
Also I noticed these vacuum line connections are open and going no where...
Any help with these issues would be greatly appreciated.:tup:
Thanks in advance
IpHoOnDyou
Re: I need some newb help...
well your missing vacume to the EGR valve, no vacume to your BOV, and no vacume to the WGA.... This will all cause your truck to run like dog shit!!! All you need to do is get vacume to those and you should be good
Fighting5thSVT
I would HIGHLY recommend one of the silicone Vacuum kits that you can purchase from this site!
ty166
what air filter are you running ?? looks like on of those foam ones from wal mart. id be affraid with the temps under the hood being what they are that foam deteriorating and getting injested into your turbo.
Mad Dog Tannen
Ok Thanks guys, I have a bigger newb question...
What is a WGA? Does that mean "Wastegate Actuator"?
I have an external wastegate.
powercat6
Yes WGA is the Wastegate actuator. Your third photo shows the Wastegate Actuator for an internal wastegate. Since you have an external WG there's no need for a vacuum line on the internal WG actuator.
