LOL...using the drop blocks, though, will that take the stock rake out of the stance of a Ty? Do you have to use regular shocks and disable the air suspension, too?
Yes you should disconnect or remove the factory air suspension first, replace the shocks (if original or leaking) then your ready for drop blocks. Sometimes depending on how low you go the axle will move foward. Set back plates can help you with that.
