Help needed in CA!
Damian
Re: Help needed in CA!
Also, the fuel injector harness, how do you tell if you put it on correctly? Im sure its simple but I just want to double check.
Throws
Are there any electrical plugs that I might have mixed up that would prevent me from starting the engine up? I dont have anything not hooked up, except that one little one wire plug that wasnt hooked up by the FPR when I bought the truck.
I think as long as you have the firing order set right and in the correct direction of rotation.... you should be all set. Are you for sure you have spark?
If I remember correctly, it's batch fire, so how the harness is laid shouldn't be an issue.
-P
Damian
I think Ive figured out my problem finally. Since it seems like the engine wants to start but cant has had me looking at my valve lashing. When I did mine, I tightened the nut down until the rocker quite moving around, and then put a half a turn more on the nut. I didnt go off of the pushrod movement like Im finding out I should have from the interwebs. So in the morning Ill go off of the push rods instead and see if that helps. Im pretty sure I over did it and the valves are stuck open.
All the imports Ive worked on just required you to torque down the rocker bolts and youre done. This old engine is definetely a learning experience for me.
Damian
Ended up being I set the valve lash wrong. Truck is put back together and running just fine.
Damian
It was a local member that came over and helped me and he almost seen a grown man cry after it finally started up. I spent so many hours, more like days, chasing things that werent wrong.
