header panel? is that the same thing as a radiator support? If so...yes they are the same - but you can get a new one from the dealer for like $60 - better off just doing that.
If its the same, you might as well cut yours up. If you need to go back to stock, buy a new one and install it. Same difference, only it saves you the work of changing the support twice.
-Rob
