Head lights activate the wipers??!!
escofield
I've tried a search or 2 on here and nothing yet, will continue to search but please feel free to post pertinent links. Here is the situation so far.
Just picked up the truck from the paint yesterday
When the headlights are on:
1.the left turn signal will turn on the wipers and spit a little washer fluid out.
the wipers will not stop until the ingnition is off and the head lights are off aswell.
2. When stopped and parked (truck running) the hazard lights will also activate the wipers and washer fluid.
3. during this time the left arrow indicator on the dash is on but dim and flashing inconsistantly.
3. The "push forward" tab for the washer fluid does not work either.
With the head lights off:
1. If I turn the wipers on they will not shut off.
2 If I do not use the wipers or lights, everything seems fine.
What I've done so far:
1. Grounds.
A. 1 on the front pass fender next to the battery(sanded off the new paint for good contact)
B. Check the other ground that is behind the driver side kick panel.
Is this my wiper stalk? Fuse?
I'm horrible with electrics (partially colorblind)
Thanks in advance
E
ty166
Re: Head lights activate the wipers??!!
id agree with that one , sounds like the multifunction switch in the column took a dump on you. not that hard to repalce one you pull the steering wheel.
escofield
that's some serious info! Thanks for taking the time to write that out. I'll be working on it tomorrow morning. Any special tools required?
Thanks again
E
This is an advanced case of the "Mystery Wipe". The intermittent wiper system in the S/T-series is dependent on the motor board 'seeing' a resistance value that is 'sent' by the wiper switch. Anything abnormal that affects this resistance will cause the board to command un-intended wiper operations.
The headlights and wipers are in no way electrically inter-connected under normal conditions. There has to be a basic body-ground problem causing this interaction. Look at anything the body-shop touched. That's the place to begin.
The washer button being 'limp' may have to do with the wipers running at weird times. When this button is depressed, the wipers run. Disconnect the wiper switch from the IP harness under the dash. The connection is the one with a pink u-shaped jumper. See if the wipers now stay still. You still have other issues, but the switch needs to be addressed as well. Start with being sure the stalk is fully/correctly seated in the switch base.
Make sure the wiper motor is well-grounded to the firewall. One of the mounts has a little ground strap around the rubber bushing. Take that bolt out, and clean everything. Bolt, strap, hole in the firewall.
The turn sig indicator dimming is a sign of a poor ground. Either at the bulb holder, or the core support to the rest of the system. Also check the ground strap from the LH head to the body by the brake booster, and the jumper from the neg batt cable to the core support.
Something isn't grounded properly, and the wiper board is interpreting this as a signal "to run" when the un-grounded turn signal is used. So don't change the wiper switch until you have all the lighting and turn sig issues sorted out. It could be the wiper switch, of course. But that's not the place to begin.
escofield
Ok. I haven't been under the dash yet, but I did check the grounds on the fire wall. I disconnected the washer fluid pump at the tank. with it disconnected my left side turn signal lights (front and rear) go dead. Connect it back up and they work????
Also noticed the fog lamps are dead... will be checking the bulbs first..
I need a volt meter
Tons of fun this weekend
escofield
Was the front core support removed? If so check the ground connections to the support at each headlight bulb. The fog grounds are here also.
If the washer pump is affecting lighting, this is a classic ground issue. The front light harness isn't grounded.
I'm pretty sure the core support wasn't removed. I'm still gonna check it out tho. Where abouts should the grounds be connected. I'm checking the syty cd but haven't found it yet. Could I just splice a ground onto the connector at the washer pump?
Also looked for the wiper connection under the dash. No luck. It's a mess under there.
Thanks
E
