ROSEDOGGYDOG
umop apisdn w,I
So I finally get my new ebay air intake on the SGT and took it out yesterday for a test run. During the run I noticed my water temp didn't quite get to the 1/4 mark. I was out for at least a good 15-20 minutes, the gauge itself gets power since its moving.
Could the sending unit really have gone bad or is it more likely that its something worse as in the instrument cluster needs to be replaced? I popped the plug wire off the sending it (damn little bugger) and it seems to be straight forward, needle plugs into sending unit and gets temp.
I picked up a Mr. Gasket radiator cap with temp. gauge and it went to 180 degrees while the dash gauge was just under the quarter mark.
Has anyone else had this same problem?
