Fuzzy Boost Controler
1992Typhoon
When I purchased my Typhoon it had a Fuzzy Boost Controler on it already. It has been functioning flawlessly until this weekend. I am now getting an overboost condition that I can not program out of the controler. It still reads all vacuum and boost. Does anyone have this controler and seen similar problems. If floored it will boost out of control and cause detonation at approximately 19.5 pounds. I have never set it above 15.4 to date and yet now it will climb out of control. It continues to read good vacuum (-17 pounds at idle in neutral and -13 pounds in gear at idle) so I doubt it is a vacuum leak. The overboost is the only problem of any kind. Any help is appreciated!
E-Rue
by pass it and see if it still over boosts. if it does, then its not the controller at all, its either a faulty wastegate, or a lean condition.
e
1992Typhoon
it ended up being the vacuum line that is attached to the waste gate. It must have blown off under boost. Thanks for the help, It is functioning perfect once again!
