So, I will post a general question here although I am using Code $59, I think it still applies across the board.
Using Tuner Pro RT to obtain data
Here are my immediate problems.
#1
Part throttle (20% +-) just about to enter boost and in 1st gear mostly, I am seeing 10+ KR. AF is in the 12's mostly and transitioning away from 14.7 on WB. I am not hammering it, just light throttle. If I give it more throttle, it goes into boost and the KR goes away. It seems to only be this transition area.
What I see is when MAP 3-Bar $3f is at 100, I am seeing about 3lbs of boost. For some reason, my MAP and boost arent matching my gauge either.
When my MAP is reading 80 in a log file, my boost starts to go above 0
I thought it was 100 kPa where it would be in boost?
#2
My f29X table has a huge bump in it in the same range as my KR and then falls off after it goes into PE. Should I move MAP PE Threshold down? What else would I change to get rid of this huge lump in my 29x table? I think there is something here related to AE or PE that is throwing it into a fit.
I WOULD THINK THIS WOULD BE THE SAME AS THE REGULAR F29 TABLE JUST EXTENDED FOR CODE $59 ?
#3
I have one log area easing into throttle where I am seeing
21 lbs of boost
0 KR
10.6 AFR (little rich)
kPA $3f is showing 231
14 deg Timing.
Question is about the kPa does it match the boost level I am seeing?
#1
#2
#3
21 lbs of boost
0 KR
14 deg Timing.
