fuel pump question
typhoonscuba
I need to drain the gas in my gas tank today because it is two years old. i want to hot wire the fuel pump and connect to the shrad valve and let it drain into a gas jug. how do i hotwire the fuel pump relay? where is the relay at.
GM TURBO
Sell Out
If you look right by the FPR - there should be a small grey wire with a male spade connector. Jumper that to the power dist box right above it.
jwaller
Evil Genius/SyTy Guru
run power to the grey lead coming out of the harness right behind the intake next to the dist on the right side.
typhoonscuba
thanks for the quick replys. i dont know what i am going to do with the old gas. i just didnt want to run old gas through the engine. maybe i will leave a little so i can make it to the gas station and mix it with so new gas.
thanks for your help
Run it threw the lawnmower, snow blower or through a daily driver. 2 years isn't that bad, I have some 5 year that I drain out of my Corvette (I drained my Corvette after 2 years thinking it would need to be drained but it didn't make that much of difference, but I didn't drive the car for another year so it need to be done). It has taken me three year to run it through my lawn mower and snow blower. Its get a little hard to start the lawn mower, but I am on my last tank ful:)
If you can, I would run your Typhoon tank low and fill it up with fresh gas.
Lynn D. Brown
Old Gas
Old Gas
Yeh, 2 yrs ain't bad. I just dump alot of fresh on top of it. Hopefully it didn't F up your Walbro if U have one because I've heard that can happen when it sits there 4 awhile.
typhoonscuba
well i drained it yesterday and i saw the first gallon or so, had a yellowish tint to it. but after that gallon the gas was perfectly clear. i drained it all out and put some fresh stuff in and it really helped. the truck ran alot better.
typhoonscuba
