Hey guys...been working fueling today on the new Ty. First off it has a modified GM BBZB 1580 chip with stock fuel & timing but revised limiters. It also has a K&N barrel filter in place of the stock airbox and a Borla catback. Last weekend I changed the old O2 sensor for one of those new Denso units (it rocks BTW...transition counts are amazingly fast). I took it out afterwards and datalogged it with the stock FPR & old fuel filter.
Closed throttle block learn (BLM) : 137-138
Open throttle block learn (BLM) : 147-150
WOT O2's : 863-934
WOT IPW : 14.9-18.6
Obviously the ECM was adding alot of fuel.
Today I installed a new AC Delco fuel filter, an adjustable regulator, and a tiny fuel pressure gauge on the rail then I started tuning for 128 open throttle block learn numbers. It took alot of fuel pressure to get there...
Fuel pressure with vaccum connected : 53-54 psi
Base fuel pressure (disco vaccum) : 62 psi
Closed throttle block learn (BLM) : 111-115
Open throttle block learn (BLM) : 126-129
WOT O2's : 894-938
WOT IPW : 12.5-15.6
Knock improved a hair (still have to do ignition though) & it doesn't feel like it's drowing (still very responsive). So what do you think? Is there a reason I should turn the fuel pressure down?
WOT O2's : 863-934
WOT IPW : 14.9-18.6
WOT O2's : 894-938
WOT IPW : 12.5-15.6
