wheels
1991 GMC Syclone #0610 $10,000 or $9,500 with stock wheels
101,000 miles
No rust.
EGR Blockoff
CS-144 alternator w/ upgraded ground cable
Odyssey PC680 battery
Hitachi mini starter
RPM 3” Exhaust w/ muffler delete
Brand new stock catalytic converter
Belltech Rear Sway Bar
Homemade bed rug
Hard line ABS delete.
Rubber I/C lines with Lightning I/C pump hotwired.
Gas Hood struts.
Two brand new front drive axles. New units.
D&R driveline HD front driveshaft
NWSTP Style Aluminum I/C Scoop
New Extang soft tonneau cover
Three pod pillar Boost, Trans Temp, and Water Temp
Remote Transmission fluid filter with temp sender
Auxiliary transmission cooler
Aluminum engine tie down
Braided brake booster vacuum line
Turbo blanket
Upper I/C Wrap
Astro Van 11 Blade Fan
A/C works.
17x9.5 & 17x11 Black ZR1’s w/ Sumitomo HTR tires 75% tread at least.
Hood stock tune
Cap/rotor, plugs, wires within 5k miles. New serpentine belt within last 2k. Fuel filter lastweek. Oil changed regularly with Mobil 1.
Original Hawaii truck, was shipped over 2 summers ago, and I bought it shortly thereafter.
Paint is good. It shines nice, but there are some imperfections if you look close. No dents or scratches.
The only "bad" things are: Previous owner drilled out the original mirror threads to put on the mirrors you see on the truck. Small hole in the drivers seat (see pictures). There is a slow oil leak from somewhere. Not enough to cause panic, but the are signs of a leak.
Truck runs great. Just drove to Detroit and back for Homecoming with no problems and got over 18mpg. Transmission is perfect. I don't need to sell the truck, so no lowball offers please.
101,000 miles
No rust.
EGR Blockoff
Homemade bed rug
Gas Hood struts.
Turbo blanket
Upper I/C Wrap
A/C works.
Hood stock tune
