djsy934
These are custom made from 48-52rc S-7 tool steel. They were precision wire edm'd and then cnc chamfered. There are no sharp edges as the stamped steel ones have that could cut your push rods. They are .187 thick instead of the .125 stamped steel. I made these a little thicker because the ARP rocker studs are a little shorter than stock and wanted more thread engagement for my poly locks. This is an extra set because I had enough material to do so, I will not make these again, one time only deal.
I offer these at $100 plus flat rate shipping to the lower 48 and any PayPal fees unless you use personal transfer in which case there are no fees. Flat rate will fit in a small box.
