FS - 1992 Aspen Blue Typhoon - LS1/4L80E Parts Included
GEN3Typhoon
1992 GMC Typhoon #0488
Aspen Blue, reported to be less than 50 Aspen Blue produced
110,000 miles
Speedhut Indiglo Gages
3 Gage A Pillar Pod
Dash Cover
OE Concepts Chrome ZR-1 Wheels (F 17x9, R 17x11)
Tires are included but are not in good shape
Also includes a set of stock wheels with two used tires
Eaton Posi Rear Differential
Richmond Locker Front Differential, rebuilt with new bearings and seals
New Hydroboost Brake Master Cylinder and Booster
LS1 Car Front Disc Brake Conversion
LS1 Car Rear Disc Brake Conversion
New Braided Stainless Lines
JS Manufacturing Coil Over kit, QA-1 shocks and front chromoly arms
Remanufactured steering box with Corvette ratio
Flaming River Steering components
Stock 700R4 Trans and BW4472 Transfer Case Included, both have 110k miles on them.
Transfer case is reported to work properly; transmission is reported to slip on the 3-4 shift.
I also have an LS1 engine with harness and PCM. This truck also has the engine
mounts and oil pan installed that are required for the Typhoon installation. Engine has Katech rod bolts installed and corvette accessories. Also has a Futral turbo friendly cam installed.
Complete upgraded 4L80E with Typhoon conversion parts and a stock truck converter.
Take the truck, the engine, transmission and everything for $7500
Frank
Re: FS - 1992 Aspen Blue Typhoon - LS1/4L80E Parts Included
Nick, see you decided to sell the truck. Looks to be in great shape. Rare color too. Good luck with the sale.
GEN3Typhoon
Thanks, thought I would put it up and see what happens.
I will put it together if nothing else.
GEN3Typhoon
Also... A few that have asked I have provided this information, I will post it here..
I know it needs a few things.
1. New front bearings - $67 each
2. Driveshafts for use with the 4L80E -
3. Braking system installed, had a NEW Hydroboost setup
4. The stock “cat back” is all that is on the truck
5. No radiator or fan with the truck
6. The clips on the driver side from cladding are broken, should be able to be fixed
7. The lower part of the bumper has rough paint
8. There is a little bit of rust over the top of the rear window, which is typical for these trucks.
The truck is going to be a great project, there are several good examples of these around as well.
I am also open to finishing the truck for someone.
GEN3Typhoon
Guy has not come through with the money as of yet, so the truck is still available.
Looking for a happy home.. haha.
double_s
how many miles on the LS1 motor & trans?
How much will you take for just the truck on its own (no motor)?
Also can you send me pics of the interior & LS1 motor?
GEN3Typhoon
Hey the engine has 28k on it and it has a Futral Cam and Katech Rod Bolts added to it.
The 4L80E trans has 0 miles on it.. it is freshly rebuilt.
I would be willing to take $6000 for the truck and associated parts with the truck, brakes, etc.
Let me know... btw email is nick.steffens@usionline.net
GEN3Typhoon
Will entertain offers on the truck separately from the rest of the parts.
Will try to sell the truck, engine and trans setup separately.
If anyone makes an offer on the trans and engine parts I will keep those offers until I sell the truck separately.
tnsyty
Saw it for sale on another forum. Love it. Wish it would go to a local TN person.
Boost27
how much for the motor and trans with all the swap parts that you have for it? thanks for you time
Kevin
GEN3Typhoon
Kevin
I would take $4000 for the following..
Engine
Harness and PCM
All conversion parts, pan, etc.
Built 4L80E trans and stock Truck Converter with Correct Flywheel
Conversion parts
Thanks,
Nick
GarnetTy1473
I might be interested in the rolling chassis and shell if you sell the drivetrain separately. Have to see if my dad wants another project since he's retired and has the time, and I don't.
GEN3Typhoon
Well the roller is for sale as well.
PM me if you are interested.
I would rather sell the truck BEFORE the driveline.
DULM
What would be required to put a stock motor back into it and be driveable?
