Front Seat Flop?
TNPhoon
1of28
Hey guys, quick question for Typhoon owners. The drivers side seat should stay in the up position right when sitting still? I mean, you shouldn't be able to grab it by the front and pull it foward without releasing the handle on the seat? Am I correct in this assumption or no?
Robert Lone
MUTANT
Re: Front Seat Flop?
Don't have a Ty, but from my experience w/ S-Blazers you should not be able to just "flop" it forward. Sounds like the lock has fallen apart or is broken. Should be a trip to the junkyard from being fixed. I am assuming the Ty seats share the same internals as the S-10 extended cabs and Blazers.
I'm prolly wrong and will get stompt directly... :rotf:
TNPhoon
1of28
Real quick, let me clarify so noone thinks I am a dumbass. I am talking about the back part of the seat, not the entire seat itself. I know there is a lever where if you are in the backseat you can pull it and the seat should go forward, I am just checking to make sure my guess is right.
gkrcr882
SyTyless......for now!
Same expierence as T-56, both seats on our Sy do it and the buckets I installed in the S-15 (from an ext. cab) do it too. I think there is a blurb in the owners manual that says that the seatbacks should move freely unless the vehicle comes to a sudden stop or is parked "nose down" on an incline, in which case you need to move the lever. Don't know if its the same on Blazers, but I would assume its the same hardware used on the pass. side seat on the ext. cab trucks.:2cents:
wantingasy
I'm not sure, but I think it's supposed to just go forward. Mine does it also...Only the drivers though
jjorgensen52
NHSTE - I'm the only one!
This is correct IMO ... I took the seat all apart trying to get the flop to stop, and found that the lever was only necessary to operate the hinge when I rotated the whole hinge assembly forward between 90 - 180 degrees.
Jersey 91/93
NASTE Member
I don't think I've ever used the lever yet. It hasn't been a big deal anytime I've driven the truck. I don't remember ever trying to move the seat while the truck was parked facing downhill, so I can't comment on that.
