if you drop the front prop shaft will the transfer case put all the power to the back wheels. If so will pulling out the prop shaft will it do any damage to the transfer case?
no it won't and yes it can...... a syty without a front propshaft is useless and in some cases have caused transfer cases to fail and in other cases not to.
