Flash'n burn question
cameronsclone
I'm trying to get these bins loaded to a chip with a flash ad burn, and don't know how to use it. All i did so far is delete the bin off the chip and put on new ones. i loaded each bin to the buffer and then hit program chip after each one. is that the correct way o set up the multi bin chip or not? i have the moates adapter with the bin switcher on it, so im good there.
sytyguy
Moderated User
Re: Flash'n burn question
Nope......doing it that way only overwrites the bin you just uploaded. You need to stack the bins. TunerPro has a stacker/splitter utility made into it (look under Tools or just hit F5 with TunerPro open). You can set the stacker up for the chip you have, load all the individual bins, and it'll stack them neatly into one bin file. Then you can go to the Flash 'n Burn and program the chip.
If you don't have TunerPro (and why not?), you can stack the bins with FileMerger (link).
Here's a pic of the bin stacker in TunerPro:
