Everyone with insanely fast trucks...
92BlkTy
How heavy are they? looking for answers from the hoovers, and guys hitting 9s/10s. Sys and Tys.
got a debate goin with a friend about how chubby our girls are when they hit ETs like that.
sytyguy
Moderated User
Surprisingly, not very light. Phil Long's Syclone is probably around 3400-3500 lbs, Ed Hess' Syclone is probably around 3800 lbs, John Waller's Typhoon is probably around 3600 lbs, and John Gerber's Typhoon is probably around 4000 lbs. That's 2 Sys/2 Tys on the opposite end of the typical weight spectrum, all running mid to high 10's.
I would suspect the Hoovers to be around 3100-3200 lbs.......not sure about Robert, McCoy, Jeff Dennis, etc.....
Personally, my truck weighed 3180 on my 7.3 eighth mile run (read - used to be that light), but my truck makes substantially less power than any of the above mentioned......as has always been evident by my lower mph on any run.
92BlkTy
jesus i had no idea you could get them that light. i figgured all the roll cages would weigh em down really badly.
probably depends on how steetable you want your 9-10 second truck and what you can live without.
ed hess
race or get outta the way
yeah the njumber above would be a close guess. only time i weighed it was 4180 withme in it.
since then took out, exhaust system
street gas tank
ac compressor
ac condenser
ac airbox
heavy metal tonneau cover
havent weighed it since removing the above.
now if my truck only weighed 31xx i cant imagine what it would run.
ed
mhoover
with me in it, im 220 lb, our truck weighs 3500 lbs. our cage only added about 60 lbs when installed. we have replaced several thing in our truck to get the weight down
MATT
MikeRenz
not stock
MATT
Do you happen to know the weight of your wheels w/ tires on them? I always wondered what those things weigh.
syclone383
MikeRenz said:
MATT
Well since I was the original purchaser of those wheels and tires and I weighted them back then, as best as I can remember the fronts weighted 50 lbs for a wheel with the tire mounted and balanced and it was 51 lbs for a rear, which is very close to what a stock wheel and tire weighs.
HTH Mike
mhoover
we've thought about it but........i think we're just goin with "MORE BOOST DAD MORE BOOST!!!! " ::thumbsup::
turbodig
syclone383 said:
MikeRenz said:
MATT
HTH Mike
That's pretty much right on what an OEM Firestone and Wheel wieghs.
That's pretty impressive, given the size of those wheels/tires... I weighed
a set of 17s and Michelins once that were something in the 72-75 lb range.
Somebody needs to make lightweight drag radials with kevlar belting...
Later,
Dig
ed hess
ya know i think i see that i have one advantage in the top 10 as far as weight goes.
i think i might be the smallest / lightest in the group! 5-6 170 lbs. lol :D
good thing since i got the heaviest sled!
ed
Jer
Don't taze me bro!
Oh crap.. I weigh 270 so I guess I need to find an ultra low weight one to offset my fat ass, right?
92BlkTy
Thats awesome. you guys help me proove my point. that these "little" trucks have big numbers on the scales and still make awesome ETs.
oh and if any of you want me to make a pass in your trucks im only 145lb :lol:
anything to help out a fellow sytyer!
Nova67ss
Robert is on a trip to US right now but I´ll try to messure him and his truck..
He is aprox 5`9" tal (as me) and in the weight about 65-70 Kg (Im much hevier tough)
Hi´s truck is around 3700Lbs, only mising item is pass side seat. the bar to the mainhoop makes it hard to have the seat there...
ed hess
270-170 = 100
100lbs = 1/10th
well jer all i can say is the difference between you and me appears to be 1/10th. lol
ed
Jer
Don't taze me bro!
ed hess said:
270-170 = 100
100lbs = 1/10th
ed
I'll remove the battery entirely to help offset that. Who needs electricity in a car, right?
decodave
MATT
So Matt
Just how much stuff did you remove to get it that light? Iv'e removed alot from mine & it's still 3510 if I remember right. Then add me & my gut at 240.
