Electric Fan - 5000 cfm
wanarace
I have be reading a few posts about electric fans. In General most aftermarket fans suck a** and couldn't cool a civic.
Now if you want an electric, the fan to get is out of a Lincon Mark 8 92-98? Yes I know it is a F*rd, but they move around 5000CFM and are pretty thin. You can usually find them at local yards for 100 bucks. The only down side is that they draw 45amps! So your electrical system better be up to par.
Later
Steve
smeagol
5000cfm is kinda hard to believe... could almost generate lift for a truck.
Most I've heard is like 2600cfm from a SPAL 16".
Maybe that's why Mark Stielow has them in his One Lap of America '69 Camaro. I've seen use of those fans in a few HotRod mags in the 90's.
warmpancakes
Ill see if we have the cfm specs at work, I work in fcsd (ford customer service ) and we write the service manuals Ken
wanarace
From everything I have heard they flow around 5000 cfm. I know for sure they can cool a big block Chevelle all day long. Go over to http://www.chevelles.com and do a search on "Mark VIII". Like I said they draw around 40amps so they better move some air.
I know they fit 68-72 Chevelle radiators perfect, I think they are around 31 inches wide.
Later
Steve
warmpancakes
According to the factory speck the flow 5125 cfm at idle (vehicle stationary) but the amp draw is 43 amp at full spin Ken
Lynn D. Brown
Lincoln Fan
Lincoln Fan
Steve,
5000 Cfm and 43 Amps - hard to believe !! I would imagine U would need a hell of a relay and wiring for that. Probably 6 or 8 Guage wire.
BigAl...
I just picked up one of these fans at a swap meet at a race, I paid $5 for it there was no way to test it so I offered the guy $5 and he said Ok. Brought it home and it works, finally a good deal for the truck.
I've already made the brackets neccesary to intall it using the stock shroud.
BigAl...
Will_in_China
Truckless Wonder
My electrical system would be scared...
How much horsepower is 45amps drawn on my marginal electrical system gonna get me?
Just doing a cost/benefit analysis here...
-Will
Lynn D. Brown
Electric fan
Electric fan
Since the stock trucks didn't even have provision for the juice for electric fans, unlike the GN, I'd say that adding 40-45 A to your demands will certainly require a hier A Alternator. Combining this w the custom wiring and electrics, I wouldn't think all of this will be worth the effort.
Loeryder
But for the A/A guys who HAVE to run electrics this could be the blessing to stomp out overheats.
By the time you've invested into A/A its time to upgrade the alternator anyways. Most guys aren't gonan put elec fans on a stock setup, unless they are just throwing cash at the truck to look cool.
Gonna have to run wires and relays for any elec fan anyways, may as well go for broke, or is it go until broke?
