rockvillespeed said:okay, i gotta get in on this one.
i say bullshit!!
10 grand in a smallblock - i could wipe every syty's 4.3's dick IN THE DIRT!
now, before everyone comes for me with torches and a rope, i LOVE MY SY!
but, in truth, i'd swap out the v6 for a 400 plus inch small block any day of the week, provided the sbc gets good efi, etc.
why? - easy - no piece of shit gm ecu and bitchy speed density, no bullshit with all our little niggly makes me wanna commit suicide problems, lighter - oh, yes, kids, it is - assuming alum heads - , ready parts availability, no heat issues, no lag, instant sick torque, more top end power, etc etc.
hell - my v8 s10 will eat my sy on it's best day up top - say, past 70 it'll literally walk away - and the sy is not stock by a long stretch, tho has nothing exotic either. and, in fairness, the v8 s10 is a 6 speed. but, what gets there first gets there first.
I was using the example of Ty with V8 so I assume that would include AWD (which we know hurts the top end and probably all around drag strip performance at 11 sec range)
Their is nothing wrong with the GM ECU or Speed Density, what do you think most of the aftermarket ECU use? Everyone I have seen uses a map sensor.
I honestly believe (if keeping the AWD) which one will be faster depends on how radical of a cam or turbo is used and how streetable it would be.
A 400+ cubic Inch Chevy is going to cost $4000 to build a short block if using forged crank which would be need for higher hp levels. Aluminum heads are $1500, Valvetrain another $1000, Fuel injection and intake $2000, plus headers, exhaust, radiator, motor mounts, oil pan will eat the rest of the budget (I am not even sure if a stroker crank's oil pan will clear the front differential) I will leave out the tranny and TC as both combo will need them. If you stick with a hydrualic cam and something with a reasonable duration for good idle, it wouldn't make much more than 550hp. A solid lifter cam would make more hp , but the valvetrain costs go up. Ofcourse this just my opinion. I am into corvette's (I have an 86) and for me it would be more money to run 11's in my Vette than Sy (and lot more money to run mid 12's which is where I hope both my vehicles are next year)
In either case The $10K budget doesn't allow for a good aftermarket ECU (aka speedopro) in either senario if you buying everything new.
The SBC would probably be easier to tune and have a better ignition system.
BTW If the V8 was 2wd it would be no contest as the weight saving would .3-4. and the luanches would be better on slicks and gain another few .1's.
