I'm in the process of building a new motor and doing code59. Is it possible to run E85?
cloned New member Apr 26, 2011 #1 I'm in the process of building a new motor and doing code59. Is it possible to run E85?
JSM Active member Apr 26, 2011 #2 Re: E85 How many? Yes, as long as your fuel system is up to the task and injectors are large enough to support the increase flow requirements.
sharkbait New member Apr 26, 2011 #3 Re: E85 How many? Use the search button. There is some good infor here on it. As said above, you'll need to flow a lot more fuel when u make the switch. Keep us posted.
