The newer radios you are seeing in GM vehicles are all double din. These all incorporate the door chime, are a five volt turn on, etc. It won't work. 2002 and before are din and a half for the most part except for a few buicks, cavaliers, and most caddys. These would work but like the guys were saying, he harness would have to change, the antenna would need an adaptor and none of your brackets will work.
If you want to graft the origional brackets on the newer deck (mid to late 90's) the stereo would work. As the only way if you don't want to use a deck from a '93 or before. As much as I hate Best buy you can go there and pick up a 60-1858. The 1858 is right but the 60 may be wrong. This is the reverse plug that would go to your new stereo. You will also need a 70-1677-1 This is the part that will attach to your existing stereo wiring harness. You will also need a 40gm20 antenna adaptor. You don't have to go to bust buy but they are the only people who stock the reverse harness.
Brian
