Gotta problem.
I drive my SY only on the weekends and a couple of weeks ago when I went to start it, it started for about 1 second and then died. Now it just cranks and cranks and cranks and nothing.
I started the following diagnostics.
1) Checked fuses. All ok.
2) Check fuel pressure at the rail. ok.
3) Check for spark. ok
4) Checked for engine codes, No codes stored.
Check engine light flashes when ignition is on.
I ran another test to see if I was getting fuel to the cylinders, so I pulled a plug, had my buddy crank the motor, and after 2 seconds of cranking, the damn thing started. I was like whoaaaaa!!!!! I put the plug back in and tried to crank it, and it doesn't start.
Am I not getting air into the mixture??? What should I check?
