intheclouds1977
When I bought my Typhoon this summer, it was in rough running shape (10°+ KR). I've spent a bit of time fixing her up and think I've finally got things running well. I'd appreciate anyone who can review the below Datamaster file and give me feedback. I may have to make some small adjustments when the weather warms up, but as far as I can tell, everything looks good in the file for now.
In the file, the strange 1st gear RPMs are due to a burnout when boost launched (cold roads), suddenly grabbing traction, then shifting to 2nd gear.
File located at:
http://www.intheclouds1977.com/Typhoon/Datamaster
Vehicle specs:
Mostly stock
No cat
VeloSyTy chip
Stock narrowband O2
Motor tune-up stuff:
- New plugs/wires/cap/rotor
- Seafoamed upper 1/2 of motor
- Rebuilt stock turbo with SportMachines upgraded impeller
- New vacuum lines and check valves
- EGR delete
- New IC pump, hotwired
- Timed to 0° base (was 6° advanced)
- Fixed false knock areas: banging tranny cooler lines, rattling broken motor mount, overtightened knock sensor
Thank you to anyone who can help!
File located at:
Vehicle specs:
Mostly stock
No cat
VeloSyTy chip
Stock narrowband O2
- EGR delete
