Wikid 1
200+ lbs of puppy!
Okay, pulled the A/C, cooling system, and everything off of the front of my motor, in prep to remove the whole thing this week. Well was looking at what all could go to free up space, and started to think. Has anyone put a radiator up in the core support where the ac condensor went? I found a alum grifin from summit for under 200 that i was thinking about having the filler removed and putting a remote filler neck on. has anyone tried this with a smaller radiator mounted in the condensor space? i'm thinking it'll seriously open the engine bay up giving plenty of room for any type of turbo inlet piping, and will be directly behind the grill allowing it to have plenty of fresh air and with the two electric fans i have now keeping it cool shouldn't be a problem
http://store.summitracing.com/partd...t=GRI-1-25241-X&N=700+400030+115&autoview=sku
theres the link to it, it already has the correct inlets/outlets on it, and is almost a perfect fit. the opening is 3.5 inches deep, 31inches wide, and 15.75 inches high. I was also thinking of having the end tanks completly repaced with a simple alum box insted of the formed end caps that are there just to make it a cleaner install.
