corvette rear independent in syclone
syclone73
hello i was just curious about this.has anyone ever heard anything on the subject.i may do some measuring and see if i can make it bolt in .i know i this will require some time to adapt and make brackets.any suggestion.need a little better control may be going to start autocrossing again.
i really used to have fun doing scca just that the truck would push very hard in turns under power .one last question has anyone here ever ( run the dragon )hwy.129 it's alot of fun.
Syclonewillie
You should talk to Al Dunstan. He has a rear coil over set up that is very nice and he also has a kit to replace the front suspension too. I will find link and put it up.
7dhamper
I plan to mount up this '78 Vette rear end as soon as I find matching front gears and discs and calipers for all 4. From what I can tell, if I do it right, I will no longer have that goofy ass offset problem and should be able to use the same rims on all 4 corners. I've helped a guy put a similar set up on a '55 with an LT1 and it road like a Cadi! My only concern is the 5 inch drop on the front with the flipped torsion adjuster arms. Turning is crunchy!
I would love to have irs out of a vette,I wonder how hard the install would be.I will have coil overs up front next Mon.,add the irs and it be the ultimate suspension.Let me know if you have any luck.
0-60N4
Re: corvette rear independent in syclone
It seems there should be some junk yard independent rear supsension that could fairly easily and cheaply be used, complete with coil-overs and disc brakes. I'm surprised it hasn't beed done yet.
