Ok, starting a running total here, so far I am upto this :
$385.24 (1x LockRight locker via turbotime)
$10.77 (2x Grease seals for axle shafts. via Napa Auto Part # 12494)
$19.98 (2x Timken bearings via Autozone part# 012313 Timken Part #SET 11 <---- These are listed as wheel bearings.... )
I am also going to show $10-15 in paint to paint the differential housing and axle shaft housings but these arent mandatory to have the project complete so I wont list above..
Another item is the $$$ to press on the new bearings to the differential carrier housing.. I could have saved some $$$ for that by doing it myself, however, there is an easier way, using the correct tools (that I dont have) so I figuired I would just bite the bullet and do it right. Thats going to be another $10-20 when I pick it up..
Then there is gear lube.. Lockright recommends running 85-140wt oil, this helps with shock loads and also quiets the 'clicking' noises made by the locker itself... I havent acquired any yet so I am not 100% on pricing but its going to be only a coupla dollars...
More pictures to come when I get a chance to throw them up.
