My wifes 92 ty is having a few cold start idling issues.I ordered a chip from waller got it put it in runs worse with his chip then the kenny bell chip that was in it.Tried calling john been a week hasn't callled me back.I put his chip in it idles a 2000-2500 check engine light is on costant ,try to throttle it it almost shuts off.So gave up with it.Put kenny bell chip back in runs fine no check engine light at all.But when you first start it in the morning it is a stubborn pig.I let it run a good 2-3 minutes before even put it in gear.As soon as you put it in gear it dies out.Restarts no problem,but you have to 2 foot it till you get her to the road then 2 foot it in to drive.After this it runs awesome....Until i hear from john i have to use this chip and get thre idle issue at cold start fixed.I checked all the vaccum lines fuel pressure,sprayed for leaks,cleaned the throttle body.My next step is cleaning iac.Plugs wires cap rotor all new,replaced vaccum lines that looked iffy.Is it a timing issue or something i am over looking...if so where do i check the timing part and what do i set it at...
