So you have a flap. Looks to be fairly thin.
Being when you tighten bolt it tightens against the inner metal sleeve, and by the looks the flap is only 1/16" thick, I would give it a shot.
It can get tricky to pull the bushings out, without good tooling so if you do have it pressed out be careful.
Don't squeeze both sides together trying to remove it.
