Ok, I DID use the search feature and even used partyboy's advice on how to understand your search feature :wink: , but I couldn't finf anything :drinking: :x .
So like the topic says I got two different codes, one is code 22 which from what I've found it has to do something with the TPS circuit and code 34 which is map sensor related. I guess the only solution for the 34 is a new map :-? ?? but, what a about the 22??
Ok, now I don't want to sound stupid or anything. But, from the info I have this two codes show up because of low voltage. I was thinking that 2 weeks ago I had to replace my battery. Did the codes appear because the battery was bad and it wasn't sending enough energy, therefore the two low voltage codes appeared??? Just a thought from a newbie with almost no mechanics Knowledge, but trying to learn.
thanx!
thanx!
