Storm Warning
Welp, got a problem with the Ty.
No start situation, with Codes 15 and 33 showing on the Scanmaster.
A few weeks ago the truck went dead while on the way to work on nightshift, had it flat-bedded home. The Scanmaster shows Codes 15 and 33. I've changed both the coolant temp sensor for a new one [Code 15] and changed out the MAP [which was a new 3-bar bought last summer] [Code 33]. Still no-start.
Fuel pressure gauge shows instant 50 psi at the rail, which stays rock solid when cranking. Truck turns over but will not start.
After pulling both ECM fuses and letting it sit for a half hour, it would suddenly start, and run, for all of 5 seconds, then go dead again.
I've done an extensive search here, and have read my Chilton's manual thoroughly. I'm at a loss as to what is going on here.
Have any of you guys encountered this situation, or have some ideas I could follow-up to get to the bottom of this? I appreciate all input. I would really like to get the Ty up and running as I want to get some runs on it at the track in another month or so.
Thanks guys.
Thanks guys.
