So my truck is almost back together and I think my transmission is on the way out if the overdrive servo is not stuck.
What transmission would you recommend?
RPM block with 2 bolt mains, roller rockers, very mild port for heads and manifold, will run alcohol injection with code 59 once break in is complete
will stick with this setup if stock trans is okay
if a built trans is needed i would modify my build for target power output is high 10- mid 11 in alaska at sea level
daily driver
pull two snowmachines, two four wheelers, or two wave runners
would prefer to stick with the 700r4
daily driver
