bezerk said:stil again, don''t know if i''am correct with the 2-4volt range of the knocksesor output (i remeber this from something).
i wished i remeber where i found that
but what if you splice the green wire (going to your boostgauge) into the knocksensor it''s wire?
just a 6 said:bezerk said:stil again, don''t know if i''am correct with the 2-4volt range of the knocksesor output (i remeber this from something).
No can do, you didn't read my last post, the knock sensor is feeding the ECU with AC voltage, the rest of the ECU and gauges are DC voltage.
You need a converter to make the AC volt from knock sensor to DC volt for the gauge.
just a 6 said:You need a converter to make the AC volt from knock sensor to DC volt for the gauge.
