I know there's something that has to be done when changing them on syty's, but I can't find the info... If I remember correctly the info was on the old syty.org, but I can't find it.
If you still have your ABS brakes, make sure that you open the bleeders so that you don't force the gunk back into the very expensive ABS unit (and ruin it) when you compress the piston to install the new pads. HTH's
If you still have your ABS brakes, make sure that you open the bleeders so that you don't force the gunk back into the very expensive ABS (and ruin them) when you compress the piston to install the new pads. HTH's
