Carpet in Typhoon
souljasmooth
I picked up a Typhoon a couple of days ago. I am in the process of changing out the interior. Has anyone replaced the carpet before in a Typhoon? I have a brand new set of carpet from a late 80's Blazer. Will this work? I want to get factory GM Carpet, but it was discontinued by GM in 03. Does anyone have a GM part number for a Blazer or Jimmy carpet that would work perfectly? Thanks
jjorgensen52
NHSTE - I'm the only one!
Re: Carpet in Typhoon
The carpet is standard Jimmy 2Dr... dark charcoal is the correct factory color. I do not have a PN, unfortunately.
I used a replacement from ACCMats, which fit 99% as well as a factory piece. It does not have the adhered backing though, you have to buy insulation seperately
