turbodig
I have the following issue on the cab corners behind the bed (underneath, where the rocks fling from the tires). This was beginning to show rust in the "snakes". This is 19k mile original paint.
I'm kicking around a few ideas-
Prime and paint back to original
Spray POR-15/KBS, then hit with primer/original paint
Black bedliner material (only in areas where it couldn't readily be seen).
I'd really like to do something more than what the factory did, because there's nothing to prevent it from happening again. On the other hand, I don't want to do something that will be a PITA to restore if she ever gets a full OEM restore job.
I have similar issues with the bottom of the bed- it's almost impossible to replicate the finish it had, primer with black overspray with fender undercoat overspray. Going theory here will be a slightly darkened gray of the KBS coatings stuff. Not 100% accurate, but looks close enough, and can be painted over if ever the crazy notion of OEM restore takes hold.
Inside of the bed is gonna be bedlinered, so I will have some of that stuff...
Thoughts/suggestions/things I haven't thought of?
