Brown wire please help!
Hello everyone, it's been awhile, almost 6 years since I rebuilt the engine and put my truck in storage. So now I'm missing the feeling of boost launches so here we go again. The reason I put it away is because anytime I disconnect the brown wire it dies and will not restart until I plug the brown wire in, it also has a very low idle and sometimes dies when in gear. I've used the search function please help!
TYRODD
My ass. Look at it.
Re: Brown wire please help!
Your timing may be so retarded that when you disconnect the tan wire, it wont run.
Try advancing your timing a bit, then back it off to where it needs to be.
MRKING
New Parts for Old Trucks
Pull your dist , get a piston stop to figure out tdc , and then reinstall .
REVEREND HARMON
Party in a box!
if your timing is dead on with the brown wire disconnected....check out the balancer...sytys like slipped balancers :)
